HTTPS Access on Zabbix
  • selimatmaca
    • Nov 2018
    OS: Ubuntu 18.04
    Zabbix: 4.0
    Hi Everyone,
    I installed Zabbix4.0 (From Package) on Ubuntu 18.04 by following the steps in the official download page(https://www.zabbix.com/download) and it works great. I need to make zabbix available for HTTPS access, so I checked the official documentation from the link below
    I created a foldernamed private for my certs with 700 permission (/etc/apache2/ssl/private)
    I copied my .crt and private key to that folder /etc/apache2/ssl/private
    Enabled ssl module (a2enmod ssl)
    Restarted Apache systemctl restart apache2
    Editted /etc/apache2/sites-available/default-ssl.conf as follows
    -------------------------------------------------------------- DocumentRoot /usr/share/zabbix
    ServerName mysite.com:443
    SSLCertificateFile /etc/apache2/ssl/primary.crt
    SSLCertificateKeyFile /etc/apache2/ssl/private/private.key --------------------------------------------------------------
    I restarted Apache again
    To test, I changed my client computer host file and added zabbix ip with its domain name.
    https://mysite.com or https://mysite.com/zabbix returns this error This site can’t provide a secure connection
    mysite.com sent an invalid response.
    ERR_SSL_PROTOCOL_ERROR
    On the other hand, http://mysite.com/zabbix works as HTTP.
    Can you please help me to configure SSL on Zabbix. I have read and tried a lot of Apache SSL configuration howtos from internet. They didn't work either.
  • selimatmaca
    • Nov 2018
    Solved. There was a problem with my crt and private key files. I re-converted my primary.crt and private.key file from pfx file by using OpenSSL with the commands below and problem is solved.
    Run the following command to export the private key: (This will generate key.pem)
    openssl pkcs12 -in certname.pfx -nocerts -out key.pem –nodes
    Run the following command to remove the passphrase from the private key: (This will generate server.key)
    openssl rsa -in key.pem -out server.key
    Run to convert certificate file pfx to crt (This will generate certificate.crt)
    openssl pkcs12 -in certname.pfx -clcerts -nokeys -out certificate.crt
    • prajaktas22
      • May 2020
      I have one question related to this. May I know what ServerName mysite.com:443 we have to define here. we already have our ssl certificates and do we need to create new for zabbix frontend installations?
