Problem Interface link down, manual recover
  • warpdan
    • Dec 2018
    I know there have been similar posts, but not a single one has a solution, so here I go again:
    I run zabbix for a cisco switch with snmp. Works fine. Now I had my notebook plugged into it and now not anymore. So Zabbix shows me that interface link is down. And I know it is down and it's good like that. How can I get rid of the problem (without disabling the check completely).
    I tried to reset the counters on the switch, clear the history of the item and disabling and enabling the trigger, no luck.
  • LenR
    • Sep 2009
    • 1011
    Sounds like you want a trigger like link was up in the past <time interval> and link is now down. You will have an alert when the link is down that goes away after some time.
    • warpdan
      • Dec 2018
      Yes, or something I can put it into the state before there was an alarm. Like I don't have all my ports connected and they don't show up. Can be also manual action.
      • warpdan
        • Dec 2018
        Found a solution:
        Added this to release expression:
        {whws02:net.if.status[ifOperStatus.{#SNMPINDEX}].last()}<>2
        or {whws02:net.if.status[ifOperStatus.{#SNMPINDEX}].diff()}=0
        so if I delete the history it gets resolved
        • ybizeul
          • Mar 2018
          • 20
          warpdan Brillant, it should be changed in the stock SNMP template.
          I applied your change at the template level and deleted all the triggers for the switches it worked great.
          I opened an issue, we'll see what happens : https://support.zabbix.com/browse/ZBX-16461
