why icmpping delay too long?
  • vnline
    • Oct 2011
    • 18
    my template define:
    my zabbix queue list stuck so long:
    queue details:
    how to optimize the icmpping?
  • ingus.vilnis
    • Mar 2014
    • 908
    Hello!
    1) In frontend open Monitoring -> Graphs --> Zabbix server --> Zabbix data gathering process busy graph and check if some processes have high values
    2) Check StartPingers parameter in your zabbix_server.conf file.
    3) Increase StartPingers (if the problem is there) and restart zabbix_server
    4) Check graphs and queue for improvements
    Best regards,
    Ingus
    • vnline
      • Oct 2011
      • 18
      Originally posted by ingus.vilnis
      Hello!
      Best regards,
      Ingus
      pinger so free
      • ingus.vilnis
        • Mar 2014
        • 908
        The graph you showed is not the one you need.
        1) In frontend open Monitoring -> Graphs --> Zabbix server --> Zabbix data gathering process busy % graph and check if some processes have high values
