hi,
i have upgraded from zabbix 1.0 to zabbix 1.1 a few weeks ago. Im
monitoring about ~50 hosts. So far only one host runs with the
new 1.1 agent, all others use agentd version 1.0
The problem is: it seems like the templates have not been updated
while upgrading (even tho i applied all database patches), which
means: i cant use the existing Host.Unix template for my 1.1 agent
(the item names differ).
How can i export the the Unix_t template from another 1.1 installation and import it into this environment without breaking
anything? (i dont want to create the template for 1.1 agents by
hand, im lazy
hand, im lazy
