hello,
I saw myself with a problem when calculating the throughput at the time of creating a template, asking for a delta with an interval .. if someone can help me?
- Poll the BIG-IP system. The following example determines TMM Client-side Throughput / Client Bits In statistics using the sysStatClientBytesIn MIB:
snmpget -v 2c -c public 192.168.10.100 .1.3.6.1.4.1.3375.2.1.1.2.1.3.0
F5-BIGIP-SYSTEM-MIB::sysStatClientBytesIn.0 = Counter64: 1059147649 - Wait for a timed interval of your choosing. The examples in this procedure use a 10 second interval.
- Poll the BIG-IP system again. The following example polls the same sysStatClientBytesIn MIB:
F5-BIGIP-SYSTEM-MIB::sysStatClientBytesIn.0 = Counter64: 1098410749 - Use the following calculation to derive the delta value:
<delta_value> = <poll_2> - <poll_1>
For example, if you use the example results from steps 3 and 5, the delta value is 39263100.
39263100 = 1098410749 - 1059147649 - Use the delta value and the Throughput calculations table to obtain the throughput statistic.
For example, if you use the example delta value from step 6, the TMM Client-side Throughput / Client Bits In throughput statistic is 31410480 bits or 3.9 MB of ingress traffic per second
| Throughput | Client In | sysStatClientBytesIn (.1.3.6.1.4.1.3375.2.1.1.2.1.3.0) |
| Client Out | sysStatClientBytesOut (.1.3.6.1.4.1.3375.2.1.1.2.1.5.0) | |
| Server In | sysStatServerBytesIn (.1.3.6.1.4.1.3375.2.1.1.2.1.10.0) | |
| Server Out | sysStatServerBytesOut (.1.3.6.1.4.1.3375.2.1.1.2.1.12.0) |
| Statistic | Calculation | |
| Throughput | In | ( <DeltaStatClientBytesIn> + <DeltasysStatClientBytesOut> ) * 8 / <interval> |
| Out | ( <DeltaStatServerBytesIn> + <DeltaServersslStatServerBytesOut> ) * 8 / <interval> | |
| TMM Client-side Throughput | Client Bits In | ( <DeltaStatClientBytesIn> * 8 ) / <interval> |
| Client Bits Out | ( <DeltaStatClientBytesOut> * 8 ) / <interval> | |
| TMM Server-side Throughput | Server Bits In | ( <DeltaStatServerBytesIn> * 8 ) / <interval> |
| Server Bits Out | ( <DeltaStatServerBytesOut> * 8 ) / <interval> |
