CPU and Memory Monitoring
  • Hello There
    • Feb 2018
    • 30
    I'd like to monitor CPU and memory usage of one process on Windows Server where the Zabbix agent is installed.
    Could you please share which key and parameters I should use?
    proc.cpu.util and proc.mem don't work.
    Thank you.
  • sancho
    • Mar 2015
    • 300
    You can do it with the perf_counters
    • Hello There
      • Feb 2018
      • 30
      Thanks for the link.
      But I am a little confused.
      Can you please show the general example for these two items I'd like to monitor?
      As I said, I'd like to monitor a specific Windows process (like explorer.exe etc), not processors.
      Thanks.
      • sancho
        • Mar 2015
        • 300
        For memory have you tested with item proc_info????
        Example:
        proc_info[explorer.exe,vmsize,sum]
        For the CPU with the perf_counters it is already a little more complicated,
        The first thing you have to do is cono is the key of the counter you need.
        For them, in CMD, drop all the counters you have running with this command.
        typeperf -qx >c:\typeperf.txt
        Or the path where you would like the txt to be saved, within that txt look for Explorer.exe, it will show you all the counters you can use for the process.
        In your case I think you would be interested.
        "\Process(explorer)\% user time"
        The item would remain:
        perf_counter["\Process(explorer)\% User Time"]
        Or something similar...
        I hope it helps
        Sorry for my English
        • Hello There
          • Feb 2018
          • 30
          proc_info[explorer.exe,vmsize,sum] = memory?
          perf_counter["\Process(explorer)\% User Time"] = CPU?
          • sancho
            sancho commented
            Exactly, try and tell us if it worked for you
