running zabbix agent with user other than zabbix
  • multazim
    • May 2018
    • 18
    I was trying to implement best practices given here.
    https://www.zabbix.com/documentation...best_practices
    1) On Ubuntu 18, I tried to run zabbix agent with a different user namely zabbix-agent using 3 steps given in the url but couldn't succeed.
    Then i tried steps given by JayC at https://www.zabbix.com/forum/zabbix-...t-user-account
    But no success. zabbix agent couldn't start with error.
    /etc/init.d/zabbix-agent script is not able to create /var/run/zabbix-agent directory, when i manually created it. agent did start but fully. stuck at activating (start) and still looking for /run/zabbix/ directory. strange.
    root@capz-zabbix03:~# systemctl status zabbix-agent.service
    ● zabbix-agent.service - Zabbix Agent
    Loaded: loaded (/lib/systemd/system/zabbix-agent.service; enabled; vendor preset: enabled)
    Active: activating (start) since Thu 2018-12-13 07:41:56 CST; 1min 28s ago
    Process: 3102 ExecStart=/usr/sbin/zabbix_agentd -c $CONFFILE (code=exited, status=0/SUCCESS)
    Tasks: 6 (limit: 4915)
    CGroup: /system.slice/zabbix-agent.service
    ├─3113 /usr/sbin/zabbix_agentd -c /etc/zabbix/zabbix_agentd.conf
    ├─3114 /usr/sbin/zabbix_agentd: collector [idle 1 sec]
    ├─3115 /usr/sbin/zabbix_agentd: listener #1 [waiting for connection]
    ├─3116 /usr/sbin/zabbix_agentd: listener #2 [waiting for connection]
    ├─3117 /usr/sbin/zabbix_agentd: listener #3 [waiting for connection]
    └─3118 /usr/sbin/zabbix_agentd: active checks #1 [idle 1 sec]
    Dec 13 07:41:56 capz-zabbix03 systemd[1]: Starting Zabbix Agent...
    Dec 13 07:41:56 capz-zabbix03 systemd[1]: zabbix-agent.service: Can't open PID file /run/zabbix/zabbix_agentd.pid (yet?) after start: No
    has anyone successfully implemented this ?
    2) If i keep "Server=127.0.0.1" in zabbix_agentd.conf and block inbound 10050 port from internet to my zabbix server then will it still be necessary to run agent as a different user?
  • Jarne St
    • Sep 2019
    • 63
    I have also this issue.
    Did anyone find a solution/workaround for this?
    • Jarne St
      • Sep 2019
      • 63
      After some research on my environment I found a solution.
      I had to modify the service file located in (/lib/systemd/system/zabbix-agent.service) to point to the new PIDFile.
      I had to change it to form
      PIDFile=/run/zabbix/zabbix_agentd.pid
      to
      PIDFile=/run/zabbix-agent/zabbix_agentd.pid
      After this modification it worked properly for my system.
      But I recommend to make a backup of this file before you change anything.
      • tim.mooney
        • Dec 2012
        • 1436
        to
        You shouldn't modify systemd service files installed in /lib/systemd by vendor packages. Your modifications will be lost any time the vendor package is updated.
        I don't love systemd, but here's one area where it really shines: you can keep the "base" zabbix-agent.service file unmodified, but place local customizations in a separate file in /etc/systemd. See the two options outlined in this post: https://serverfault.com/questions/84...ream-unit-file . The 2nd option (the .conf file) is probably closer to what you need, since you only need to alter one or two things (PIDFile and User, probably).
        Also, keep in mind that /run is a dynamic, memory-based filesystem. You manually created /run/zabbix-agent and set permissions on it for your custom zabbix-agent user, but that directory will go away the next time your system is rebooted. There's a mechanism to deal with that: man tmpfiles.d(5) . Since the vendor package for Zabbix should be installing a /usr/lib/tmpfiles.d/zabbix.conf file, you can probably just copy that to /etc/tmpfiles.d/zabbix-agent.conf and change the path (arg 2 in the file) and user and potentially group. If you do that, systemd will automatically recreate /run/zabbix-agent for you.
        • Jarne St
          • Sep 2019
          • 63
          yes
          I maked a file in /etc/tmpfiles.d/zabbix-agent.conf to include the path to the pid file
          And reloaded the configuration and it worked!
