Hi
I'm having trouble to monitor the CPU usage of the F5 using the template from "https://github.com/dimachait/zabbix-templates/tree/master/F5/zabbix-3.x", the error is in as in the image. Using SNMPWALK I found that I can pull data correctly if without the square brackets in OID. But I got an error if I try to delete the brackets in the key directly. Could anyone help?
