How To View Unsupported Items?
  • vinyltears
    • Jul 2013
    Hello I have Zabbix server 1.8.5 on a solaris 10 zone.
    The GUI tells me I have 642 unsupported items ...
    Amount of unsupported items 15 Apr 2014 16:58:00 642
    I can't find a way to display what those items are so I can disable them?
    In the zabbix_server.log I do see some messages about items changing status from supported to not then back to supported again, this happens if the zone runs out of swap space...
    24768:20140415:074536.078 Item [hostname:solaris.vm.memory.swap.unalloc] is not supported
    24761:20140415:074537.758 Item [hostname:solaris.vm.memory.size.used] is not supported
    24727:20140415:074538.438 Item [hostname:solaris.vm.memory.size.free] is not supported
    24716:20140415:074541.498 Item [hostname:solaris.net.failed[bge31000]] is not supported
    24716:20140415:074547.908 Item [hostname:solaris.net.failed[bge44000]] is not supported
    24751:20140415:074547.988 Item [hostname:solaris.net.failed[bge53000]] is not supported
    24731:20140415:074549.728 Item [hostname:solaris.net.failed[bge54000]] is not supported
    24860:20140415:075338.207 Item [hostname:solaris.vm.memory.size.free] became supported
    24860:20140415:075338.235 Item [hostname:solaris.vm.memory.swap.unalloc] became supported
    24861:20140415:075339.487 Item [hostname:solaris.vm.memory.size.used] became supported
    24855:20140415:075410.392 Item [hostname:solaris.net.failed[bge31000]] became supported
    24853:20140415:075414.672 Item [hostname:solaris.net.failed[bge44000]] became supported
    24853:20140415:075414.673 Item [hostname:solaris.net.failed[bge53000]] became supported
    24852:20140415:075425.017 Item [hostname:solaris.net.failed[bge54000]] became supported
    It doesn't seem to give these messages if I restart Zabbix server.
    I have looked through the items view on all my hosts but the status isn't set to unsupported on any.
    Apologies if this is a previously answered question but I found nothing when searching the forum and google.
    Many thanks for any help, this isn't an urgent issue btw, just something I want to tidy up.
    Regards Chris
  • tchjts1
    • May 2008
    • 1605
    Look at this screenshot. I believe this same functionality is in the version of Zabbix you are using. Maybe not though.
    Anyway, go to Configuration --> Hosts and then click on "Items" for any host. Doesn't matter what host. Once there, now click on the "Filter" link at the top middle to expand the filter section. Clear the host name from the "Host" box so it is empty, set "Status" dropdown box to "Not Supported" and then click on the "Filter" button. There ya go... all your unsupported items.
    • vinyltears
      • Jul 2013
      That's great thanks, now I just have to find a way to fix them all.
      Cheers Chris
      • shtrull
        • Nov 2015
        hidden items
        i know of this way to find the unsupported items.
        but even if i enabled all the unsupported items i have 1 unsupported in the counter, how can i find on the servers side this missing item?
        even that the server is set to refresh the unsupported every two minutes this item dosn't clear...
        • MR_Andrew
          • Dec 2015
          • 27
          Hello! Looks like I have the same issue.
          I checked my items. But Zabbix Server (3.4) status show me 664 disabled items. Some of them are really disabled - near 40-50. But other - I can't find it what the items are disabled?
          Please, help me.
          Thanks a lot!
          • MR_Andrew
            • Dec 2015
            • 27
            Update
            Sorry, stupid me. This disabled items - items from disabled hosts. For example, I have 1 unused disabled switch with 400+ disabled items. Removed it and number of items decreased.
            Thanks a lot
