{{HOST.NAME1}:eventlog[System].last(0)} is not working
  • dzapata
    • Apr 2012
    • 17
    Hi everyone,
    I write you because I'm having troubles with the macro {{HOST.NAME1}:eventlog[System].last(0)}. I configured an action that send an email with the macro {{HOST.NAME1}:eventlog[System].last(0)}, however the mail I receive doesn't convert {{HOST.NAME1}:eventlog[System].last(0)} to the correct value. It shows in the message '{{HOST.NAME1}:eventlog[System].last(0)}'.
    ¿What is wrong with the macro?
    The message of the action is configured this way:
    A continuacion los datos del problema
    Trigger: {TRIGGER.NAME}
    Trigger status: {TRIGGER.STATUS}
    Servidor: {HOST.NAME1}
    Informacion Adicional:
    {ITEM.VALUE1}
  • pc99096
    • Oct 2011
    • 193
    i am not sure if you can use something like eventlog[System].last(0) in actions
    why don't you use the standard
    {ITEM.NAME1} ({HOST.NAME1}:{ITEM.KEY1}): {ITEM.VALUE1}
