active check got (ZAB_TCP_READ) time out
  • mehdiaghayari
    • Dec 2018
    I used zabbix appliance docker image (centos created 2018-11-26) on docker-ce (17.06.0) with below command.
    docker run --restart=always --name zabbix -h zabbix -e ZBX_SERVER_NAME="zabbix" -p 80:80 -p 10051:10051 -d zabbix/zabbix-appliance:centos-trunk
    also I used zabbix-agent (rpm version) on centos 6 and 7, after restart zabbix-agent, I got bellow error.
    active check configuration update from [zabbix_server_IP:10051] started to fail (ZAB_TCP_READ) time out()
    also, I set Server and ServerActive and ,... on zabbix_agentd.conf and there is no network or firewall problem because below telnets are OK:
    telnet zabbix_server_ip:10051
    telnet zabbix_agent_ip:10050
    but, zabbix agent (active) items not working, for example log[] and logrt[]
    please assist me.
  • mehdiaghayari
    • Dec 2018
    Additional information:
    zabbix_agentd.conf
    PidFile=/var/run/zabbix/zabbix_agentd.pid
    LogFile=/var/log/zabbix/zabbix_agentd.log
    LogFileSize=0
    DebugLevel=3
    EnableRemoteCommands=0
    LogRemoteCommands=0
    Server=x.x.x.x
    ServerActive=x.x.x.x
    Hostname=zabbix
    Timeout=20
    Include=/etc/zabbix/zabbix_agentd.d/*.conf
    zabbix_server.conf
    LogType=console
    DBHost=localhost
    DBName=zabbix
    DBUser=zabbix
    DBPassword=********
    DBPort=3306
    javaGateway=localhost
    javaGatewayPort=10052
    StartJavaPollers=5
    Timeout=13
    AlertScriptsPath=/usr/lib/zabbix/alertscripts
    ExternalScripts=/usr/lib/zabbix/externalscripts
    Also there is no same issue on zabbix server (rpm package) that installed on centos 7.
    Is there any idea?
    • mehdiaghayari
      • Dec 2018
      I increase DebugLevel to 4 on agent and there is bellow logs
      18587:20181225:152349.105 In zbx_tls_init_child()
      18587:20181225:152349.108 OpenSSL library (version OpenSSL 1.0.1e-fips 11 Feb 2013) initialized
      18587:20181225:152349.108 End of zbx_tls_init_child()
      18587:20181225:152349.108 In init_active_metrics()
      18587:20181225:152349.108 buffer: first allocation for 100 elements
      18587:20181225:152349.108 End of init_active_metrics()
      18587:20181225:152349.108 In send_buffer() host:'172.17.0.2' port:10051 entries:0/100
      18587:20181225:152349.108 End of send_buffer():SUCCEED
      18587:20181225:152349.108 __zbx_zbx_setproctitle() title:'active checks #1 [getting list of active checks]'
      18587:20181225:152349.108 In refresh_active_checks() host:'172.17.0.2' port:10051
      18586:20181225:152349.087 agent #4 started[listener #3]
      18586:20181225:152349.094 In zbx_tls_init_child()
      18586:20181225:152349.100 OpenSSL library (version OpenSSL 1.0.1e-fips 11 Feb 2013) initialized
      18586:20181225:152349.101 End of zbx_tls_init_child()
      18586:20181225:152349.101 __zbx_zbx_setproctitle() title:'listener #3 [waiting for connection]'
      18583:20181225:152349.104 agent #1 started [collector]
      18583:20181225:152349.105 In init_cpu_collector()
      18583:20181225:152349.105 End of init_cpu_collector():SUCCEED
      18583:20181225:152349.105 __zbx_zbx_setproctitle() title:'collector [processing data]'
      18583:20181225:152349.105 In update_cpustats()
      18583:20181225:152349.105 End of update_cpustats()
      18583:20181225:152349.105 __zbx_zbx_setproctitle() title:'collector [idle 1 sec]'
      18587:20181225:152349.105 agent #5 started [active checks #1]
      18584:20181225:152349.109 agent #2 started[listener #1]
      18584:20181225:152349.109 In zbx_tls_init_child()
      18584:20181225:152349.112 OpenSSL library (version OpenSSL 1.0.1e-fips 11 Feb 2013) initialized
      18584:20181225:152349.112 End of zbx_tls_init_child()
      18584:20181225:152349.112 __zbx_zbx_setproctitle() title:'listener #1 [waiting for connection]'
      18585:20181225:152349.112 OpenSSL library (version OpenSSL 1.0.1e-fips 11 Feb 2013) initialized
      18585:20181225:152349.112 End of zbx_tls_init_child()
      18585:20181225:152349.112 __zbx_zbx_setproctitle() title:'listener #2 [waiting for connection]'
      18587:20181225:152349.112 sending [{"request":"active checks","host":"zabbix"}]
      18587:20181225:152349.112 before read
      18585:20181225:152349.460 __zbx_zbx_setproctitle() title:'listener #2 [processing request]'
      18585:20181225:152349.461 Requested [system.cpu.util[,guest]]
      18585:20181225:152349.461 Sending back [0.000000]
      18585:20181225:152349.461 __zbx_zbx_setproctitle() title:'listener #2 [waiting for connection]'
      18583:20181225:152350.106 __zbx_zbx_setproctitle() title:'collector [processing data]'
      18583:20181225:152350.106 In update_cpustats()
      18583:20181225:152350.106 End of update_cpustats()
      18583:20181225:152350.106 __zbx_zbx_setproctitle() title:'collector [idle 1 sec]'
      18584:20181225:152350.463 __zbx_zbx_setproctitle() title:'listener #1 [processing request]'
      18584:20181225:152350.463 Requested [system.cpu.util[,guest_nice]]
      18584:20181225:152350.463 Sending back [0.000000]
      18584:20181225:152350.463 __zbx_zbx_setproctitle() title:'listener #1 [waiting for connection]'
      18583:20181225:152351.106 __zbx_zbx_setproctitle() title:'collector [processing data]'
      18583:20181225:152351.106 In update_cpustats()
      18583:20181225:152351.107 End of update_cpustats()
      18583:20181225:152351.107 __zbx_zbx_setproctitle() title:'collector [idle 1 sec]'
      18586:20181225:152351.465 __zbx_zbx_setproctitle() title:'listener #3 [processing request]'
      18586:20181225:152351.465 Requested [system.cpu.util[,idle]]
      18586:20181225:152351.465 Sending back [90.355330]
      18586:20181225:152351.466 __zbx_zbx_setproctitle() title:'listener #3 [waiting for connection]'
      18583:20181225:152352.108 __zbx_zbx_setproctitle() title:'collector [processing data]'
      18583:20181225:152352.108 In update_cpustats()
      18583:20181225:152352.108 End of update_cpustats()
      18583:20181225:152352.108 __zbx_zbx_setproctitle() title:'collector [idle 1 sec]'
      18585:20181225:152352.468 __zbx_zbx_setproctitle() title:'listener #2 [processing request]'
      18585:20181225:152352.468 Requested [system.cpu.util[,interrupt]]
      18585:20181225:152352.468 Sending back [0.000000]
      18585:20181225:152352.469 __zbx_zbx_setproctitle() title:'listener #2 [waiting for connection]'
      18583:20181225:152353.108 __zbx_zbx_setproctitle() title:'collector [processing data]'
      18583:20181225:152353.108 In update_cpustats()
      18583:20181225:152353.109 End of update_cpustats()
      18583:20181225:152353.109 __zbx_zbx_setproctitle() title:'collector [idle 1 sec]'
      18584:20181225:152353.469 __zbx_zbx_setproctitle() title:'listener #1 [processing request]'
      18584:20181225:152353.469 Requested [system.cpu.util[,iowait]]
      18584:20181225:152353.469 Sending back [0.000000]
      18584:20181225:152353.470 __zbx_zbx_setproctitle() title:'listener #1 [waiting for connection]'
      18583:20181225:152354.109 __zbx_zbx_setproctitle() title:'collector [processing data]'
      18583:20181225:152354.109 In update_cpustats()
      18583:20181225:152354.109 End of update_cpustats()
      18583:20181225:152354.109 __zbx_zbx_setproctitle() title:'collector [idle 1 sec]'
      18587:20181225:152354.109 active check configuration update from [172.17.0.2:10051] started to fail (ZBX_TCP_READ() timed out)
      18587:20181225:152354.109 End of refresh_active_checks():FAIL
      18587:20181225:152354.110 __zbx_zbx_setproctitle() title:'active checks #1 [processing active checks]'
      18587:20181225:152354.110 In process_active_checks() server:'172.17.0.2' port:10051
      18587:20181225:152354.110 End of process_active_checks()
      18587:20181225:152354.110 In get_min_nextcheck()
      18587:20181225:152354.110 End of get_min_nextcheck():-1
      18587:20181225:152354.110 In send_buffer() host:'172.17.0.2' port:10051 entries:0/100
      18587:20181225:152354.110 End of send_buffer():SUCCEED
      18587:20181225:152354.110 __zbx_zbx_setproctitle() title:'active checks #1 [idle 1 sec]'
      18586:20181225:152354.470 __zbx_zbx_setproctitle() title:'listener #3 [processing request]'
      18586:20181225:152354.471 Requested [system.cpu.util[,nice]]
      18586:20181225:152354.471 Sending back [0.000000]
      18586:20181225:152354.471 __zbx_zbx_setproctitle() title:'listener #3 [waiting for connection]'
      18583:20181225:152355.110 __zbx_zbx_setproctitle() title:'collector [processing data]'
      18583:20181225:152355.110 In update_cpustats()
      18583:20181225:152355.110 End of update_cpustats()
      18583:20181225:152355.110 __zbx_zbx_setproctitle() title:'collector [idle 1 sec]'
      anybody can help me?
      • mehdiaghayari
        • Dec 2018
        I tested, host network on docker with bellow command:
        docker run --restart=always --name zabbix --network host -h zabbix -e ZBX_SERVER_NAME="zabbix" -p 80:80 -p 10051:10051 -d zabbix/zabbix-appliance:centos-trunk
        so issue is resolved
        please edit bellow manual or edit docker image for other people.
