Defining a host trigger that works accross two hosts
  • dmcgrath
    • Dec 2018
    Hi
    I am running zabbix 3.4
    I have two servers with a floating IP address. I have two custom monitors (one one each server) with key server1_floating_ip and server2_floating_ip. server 1 should normally have the IP address, and I consider my cluster failed over if server 2 has the address.
    The custom monitors return 0 if the server has the floating IP and non zero if not. (I used regex as sometime my monitor scripts return a text error)
    I defined a trigger against server1
    {server1:_server1_public_floating_ip.regexp(^0$,#1 )}=0 which sets OK if server 1 has IP and problem if it does not. (works as expected)
    I then defined a trigger against server2
    {server1:server1_floating_ip.regexp(^0$,#1)}=1 and {server2:server2_floating_ip.regexp(^0$,#1)}=0 which sets OK if server 1 has IP and sever 2 does not have server IP. This is working as expected.
    I then tried to modify the trigger for server2 so that if server 1 has IP and server 2 does not OR server 1 has not go the IP address but sever 2 has the IP address then to set OK. This means server 2 should show OK if server 1 or server 2 have the ip address So my final trigger expression is
    or
    {server1:server1_floating_ip.regexp(^0$,#1)}=0 and {server2:server2_floating_ip.regexp(^0$,#1)}=1
    So if the address is on server 2 I want the server 1 trigger to show problem and the server 2 trigger to show OK. But when I add the the or to the expression the trigger returns problem when server 2 has the IP Address.
    I have noticed that once I mentioned server 1 in the server 2 trigger it shows as a trigger on both server 1 and server 2. It seems like zabbix is eval the trigger I hoped was defined against server 2 against sever 1 and server 2 at the same time.
    Regards
    David
  • kloczek
    • Jun 2006
    • 1771
    - create dummy host (127.0.0.1 in interface)
    - add trigger which parts of the expression will be using metrics from other two hosts
    • dmcgrath
      • Dec 2018
      Thanks for the suggestion I managed to solve the problem myself whilst waiting for my post to be moderated.
      I solved it by updating my expression with an extra pair of brackets and making the whole expression equal to zero!
      or
      )=0
      Happy Christmas everyone :-)
      David
