no more space left
  • mdasilva
    • Feb 2006
    no more space left
    ack. I have a 25gb partition for the mysql db that zabbix uses. There is no more space. Whats the best way of reducing the space used? Is there a way to flush older records from zabbix? Im even willing to flush all data as long as the configuration remains.
    Please advise.
  • sid
    • Jul 2006
    • 44
    You could increase the interval at which zabbix takes statistics. This would help slow down the increase in data.
    You can also reduce the number of days that zabbix holds on to data. This would help with data alread acquired.
    And yes, you can also purge ur database.
    Hope this helps
