Notification when current traffic exceeds 50% of the previous month's
  • ZabbixFun
    • Apr 2014
    • 23
    Hi all,
    Although I use zabbix for a few years now, this is my first post on the forums.
    First of all I would like to say a big thanks to the developers, as it is a great piece of software and helped me a lot in monitoring all kinds of services.
    And I really hope I will be able to attend this year's conference.
    You guys have a lot more experience in configuring zabbix than me, so I would like to ask you if it is possible to create a notification when (in and/or out) traffic exceeds 50% of the previous month's average traffic.
    I understand that to calculate the total bandwidth on eth0 I can use:
    last("net.if.in[eth0,bytes]")+last("net.if.out[eth0,bytes]")
    And to calculate the percentage of incoming traffic I can use:
    100*last("net.if.in[eth0,bytes]")/(last("net.if.in[eth0,bytes]")+last("net.if.out[eth0,bytes]"))
    But, is there a way to retrieve the last month's average traffic, compare it with the current month's traffic and then receive a notification?
    This is mainly to see if there is a big increase of traffic that would indicate a possible issue.
    May be there is a better and easier solution for this, so any help or links to other posts is appreciated.
    Thanks in advance.
    Kind regards
  • jan.garaj
    • Jan 2010
    • 506
    Some functions support time shifting. Also last() supports it, so use it (30days = 43200seconds):
    {last("net.if.in[eth0,bytes]")+last("net.if.out[eth0,bytes]") / last("net.if.in[eth0,bytes]",43200)+last("net.if.out[eth0,bytes]",43200)} > 1.5
    {100*last("net.if.in[eth0,bytes]")/(last("net.if.in[eth0,bytes]")+last("net.if.out[eth0,bytes]"))/
    100*last("net.if.in[eth0,bytes]",43200)/(last("net.if.in[eth0,bytes]",43200)+last("net.if.out[eth0,bytes]",43200))} > 1.5
    Test and debug it, it's only untested concept ;-) IMHO, it'll be better if you use avg() function instead of last() (eg. hour average). Eventually you can have a problem with spikes. But you know your infrastructure and what do you need. So maybe last() is the best option for you.
    • ZabbixFun
      • Apr 2014
      • 23
      Thanks jan.garaj,
      It seems that avg() with time_shift would be the best solution, however I don't know whether traffic spikes would cause many false alarms.
      I will test it and post the results.
      Thank you for your answer.
      Regards,
