From this code:
I'm getting:
breaches
rerun_late
mxpp01
changes
i want from above output to create JSON output in following format. From this output i'm trying to create Zabbix external script
Desired output
I modified above script:
But getting:
"data": [
"{#job}": "breaches"
"data": [
"{#job}": "rerun_late"
"data": [
"{#job}": "mxpp01"
"data": [
"{#job}": "changes"
items = items[0].split()
for emailid in items:
resp, data = conn.uid("fetch",emailid, "(RFC822)")
if resp == 'OK':
email_body = data[0][1].decode('utf-8')
mail = email.message_from_string(email_body)
#print email_body
if mail["Subject"].find("PA1") > 0 or mail["Subject"].find("PA2") > 0:
regex1 = r'(?<!^)JOB:\s*(\S+)'
#regex2 = r'Job finished'
#c=re.findall(regex2, email_body, re.IGNORECASE)
a=re.findall(regex1 ,email_body) #re.IGNORECASE)
if a:
b=set(a)
seen = set()
result = []
for item in a:
if item not in seen:
seen.add(item)
result.append(item)
output = " ".join(result)
I'm getting:
breaches
rerun_late
mxpp01
changes
Desired output
"data": [
"{#job}": "mxpp01"
"{#job}": mxpp01"
"{#job}": "changes"
if resp == 'OK':
#print email_body
if a:
b=set(a)
seen = set()
result = []
for item in a:
seen.add(item)
result.append(item)
data = [{"{#job}": output}]
print json.dumps({"data": data}, indent=4)
"data": [
"data": [
"data": [
"{#job}": "mxpp01"
"data": [
"{#job}": "changes"
