Hello. I want to make zabbix send SMS when the trigger is activated .
FreeBSD 8 , Zabbix 1.8, SMSTools
Trying to implement it with a script that uses zabbix:
/usr/local/etc/zabbix/externalscripts /sms_send.sh
The problem is that the /var/spool/sms/outgoing file is created with the owner zabbix:dialer and permission are read / write by owner and nothing sending out .
If I give more permissions give or just change the owner to uucp then messages sends immediately .
How to make that script create a file with the owner uucp:dialer?
I'm add user 'zabbix' to the uucp group and dialer groupr, restart zabbix_server, but the file is still have owner zabbix:dialer
in a file /usr/local/share/smstools/sendsms:
file smsd.conf:
# Cat / tmp / zabbix_server.log
SMS sends fine from the command line (root)
I think to try run a script via sudo with user uucp, but maybe there is another way to solve this?
Thanks and sorry for english.
#! / bin / sh
to = $ 1
subject = "$ 2"
body = "$ 3"
sendsms $ to "$ subject" "$ body"
to = $ 1
subject = "$ 2"
body = "$ 3"
inspection # pw groupmod uucp-m zabbix
inspection # pw groupmod dialer-m zabbix
inspection # pw groupshow dialer
dialer: *: 68 : zabbix
inspection # pw groupshow uucp
uucp: *: 66 : zabbix
inspection # rehash
inspection # /usr/local/etc/rc.d/zabbix_server restart
inspection # rehash
smsd_user = "uucp"
devices = huaweiE150
loglevel = 7
# loglevel 7 - maximum output for debugging
USER = uucp
GROUP = dialer
PIDFILE = / var / run / smsd / smsd.pid
INFOFILE = / var / run / smsd / smsd.working
outgoing = / var / spool / sms / outgoing
checked = / var / spool / sms / checked
incoming = / var / spool / sms / incoming
failed = / var / spool / sms / failed
sent = / var / spool / sms / sent
autosplit = 3
[huaweiE150]
device = / dev/cuaU4.0
baudrate = 115200
rtscts = no
init = at + cpms = "sm", "sm", ""
incoming = yes
incoming = high
pin = 0000
memory_start = 0
loglevel = 7
USER = uucp
GROUP = dialer
autosplit = 3
[huaweiE150]
baudrate = 115200
rtscts = no
incoming = yes
incoming = high
pin = 0000
memory_start = 0
chown: / tmp / smsd_foCFRN: Operation not permitted
mv: / var/spool/sms/outgoing/send_ZF3g6E: set owner / group (was: 122/ 0 ): Operation not permited
