Monitor RDP Session Username
  • Hello There
    • Feb 2018
    • 30
    Hello.
    I would like to check for a user that uses RDP session (monitor a session username)... Is it possible?
    Thanks.
  • boyemillar
    • Nov 2015
    • 33
    I have a Powershell script which runs via a user parameter on the local Zabbix Agent and returns a list of the active RDP sessions or "No-Login" if there is no login.
    • Hello There
      • Feb 2018
      • 30
      Can you please provide any info that would help me? Thanks.
      • boyemillar
        • Nov 2015
        • 33
        Here is the Powershell script
        Create an item called "whoami" on the host which you want to monitor
        Add a User parameter on the Zabbix Agent Conf file (change the path to the powershell script as required)
        UserParameter=whoami,powershell -NoProfile -ExecutionPolicy Bypass -File c:\zabbix\plugins\zbx-whoami\whoami.ps1
        clear
        function Convert-QueryToObjects
            [CmdletBinding()]
            [Alias('QueryToObject')]
            [OutputType([PSCustomObject])]
            param
                [Parameter(Mandatory = $false,
                           ValueFromPipeline = $true,
                           ValueFromPipelineByPropertyName = $true,
                           Position = 0)]
                [Alias('ComputerName', 'Computer')]
                [string]
                $Name = $env:COMPUTERNAME
            Process
                Write-Verbose "Running query.exe against $Name."
                $Users = query user /server:$Name 2>&1
                if ($Users -like "*No User exists*")
                    # Handle no user's found returned from query.
                    # Returned: 'No User exists for *'
                    #Write-Error "There were no users found on $Name : $Users"
                    #Write-Verbose "There were no users found on $Name."
                    Write-Host No-Login
                elseif ($Users -like "*Error*")
                    # Handle errored returned by query.
                    # Returned: 'Error ...<message>...'
                    #Write-Error "There was an error running query against $Name : $Users"
                    #Write-Verbose "There was an error running query against $Name."
                    Write-Host Error
                elseif ($Users -eq $null -and $ErrorActionPreference -eq 'SilentlyContinue')
                    # Handdle null output called by -ErrorAction.
                    Write-Verbose "Error action has supressed output from query.exe. Results were null."
                else
                    Write-Verbose "Users found on $Name. Converting output from text."
                    # Conversion logic. Handles the fact that the sessionname column may be populated or not.
                    $Users = $Users | ForEach-Object {
                        (($_.trim() -replace ">" -replace "(?m)^([A-Za-z0-9]{3,})\s+(\d{1,2}\s+\w+)", '$1  none  $2' -replace "\s{2,}", "," -replace "none", $null))
                    } | ConvertFrom-Csv
                    Write-Verbose "Generating output for $($Users.Count) users connected to $Name."
                    # Output objects.
                    foreach ($User in $Users)
                        Write-Verbose $User
                        if ($VerbosePreference -eq 'Continue')
                            # Add '| Out-Host' if -Verbose is tripped.
                            [PSCustomObject]@{
                                ComputerName = $Name
                                Username = $User.USERNAME
                                SessionState = $User.STATE.Replace("Disc", "Disconnected")
                                SessionType = $($User.SESSIONNAME -Replace '#', '' -Replace "[0-9]+", "")
                            } | Out-Host
                        else
                            # Standard output.
                            [PSCustomObject]@{
        Convert-QueryToObjects | ForEach-Object {
                if ($_.SessionState -eq 'Active') {
                    Write-Host -NoNewline $_.UserName ""
                elseif ($_.SessionState -eq 'Disconnected') {
                    Write-Host -NoNewline "^" $_.UserName ""
            Write-Host
        • Hello There
          • Feb 2018
          • 30
          Thanks. I'll try that now.
          • Hello There
            • Feb 2018
            • 30
            It says Unsupported item key.
            I configured it like this...
            • boyemillar
              • Nov 2015
              • 33
              Mines is set to Zabbix Agent Active
              Can you run the script in Powershell just to make sure you get an output
              • Hello There
                • Feb 2018
                • 30
                Yes, I can run the script.
                • boyemillar
                  • Nov 2015
                  • 33
                  Is there anything in the Zabbix log on the agent side...? I'm assuming the agent is setup to allow ServerActive checks
                  • Hello There
                    • Feb 2018
                    • 30
                    Since I've installed Zabbix Agent (three days ago), it says
                    "1060:20190108:071202.672 no active checks on server [192.9.102.17:10051]: host [Windows host] not found"
                    Yes, I have specified an IP addresses for both... for Server Passive checks as well as for Server Active checks in zabbix_agentd.conf.
                    This is my configuration of the server in Zabbix... See the attachment.
                    • boyemillar
                      • Nov 2015
                      • 33
                      You dont need the extra interface on the host "10051" ... Here is my config from the Host side.
                      Can you post your Agent conf file..?
                      • Hello There
                        • Feb 2018
                        • 30
                        Before we continue I'd like to share my goal. I want to create a trigger that will warn me if a particular user logs to a particular computer via RDP.
                        • boyemillar
                          • Nov 2015
                          • 33
                          I just use this "whoami" item to monitor if there is a logged on user on one of a set of 20 particular machines.... i can then look back to see who has been logged in over the past number of hours. A simple regex trigger could easily be setup to warn if a particular username logs in but it's not something i require.
