zabbix agent installation fails on solaris 10
  • rohitist
    • Apr 2014
    • 30
    Zabbix agent installation fails while running configure with below shown error:
    checking for -m64 compilation flag... yes
    checking for architecture... solaris (solaris2.10)
    checking for ICONV support... configure: error: Unable to use iconv (libiconv check failed)
    I have checked the config.log file also and there is no useful trace to paste here.
    Do i need to define some environment variables? If yes, then how?
    Please help me to identify the issue.
  • steveboyson
    • Jul 2013
    • 582
    Are you sure you have libiconv in 64bit installed? You are trying to compile with "-m64" which requires 64bit libraries.
    • rohitist
      • Apr 2014
      • 30
      Solved !!
      Thanks for your reply.
      I went through many blogs and somewhere I found below parameters to use. And it worked !!
      export LD_LIBRARY_PATH=/opt/coolstack/lib/
      LIBS=-liconv LDFLAGS=-L/usr/lib ./configure --enable-agent
      Thank you again for your time.
