Hi all,
Having problem setting up a agent on Solaris 11. From RTFM and some google I've installed the agent from https://www.opencsw.org/packages/CSWzabbix-agent/
From following the install instructions I get a print out of
I've change the configs to point at my zabbix server and changed the hostname.
Looking at 'top' there is no service running for zabbix so have check svcs and there is not service either, and nothing in init.d. I have tried running svcadm enable zabbix-agent but get back ''zabbix-agent' doesn't match any instances'
Is the agent set up like linux where you need to enable and start zabbix? Could anyone point me in the right direction?
/etc/opt/csw/zabbix_agent.conf.CSW f cswpreserveconf 0644 root bin 2272 63346 1340696534 CSWzabbix-agent
/etc/opt/csw/zabbix_agent.conf.d d none 0755 root bin CSWzabbix-agent
/etc/opt/csw/zabbix_agentd.conf.CSW f cswpreserveconf 0644 root bin 5764 20316 1340696534 CSWzabbix-agent
/etc/opt/csw/zabbix_agentd.conf.d d none 0755 root bin CSWzabbix-agent
/opt/csw/bin/sparcv8plus/zabbix_get f none 0755 root bin 142284 55650 1340696530 CSWzabbix-agent
/opt/csw/bin/sparcv8plus/zabbix_sender f none 0755 root bin 162080 44740 1340696530 CSWzabbix-agent
/opt/csw/bin/sparcv9/zabbix_get f none 0755 root bin 166240 25256 1340696534 CSWzabbix-agent
/opt/csw/bin/sparcv9/zabbix_sender f none 0755 root bin 190416 20703 1340696534 CSWzabbix-agent
/opt/csw/bin/zabbix_get=/opt/csw/bin/isaexec l none CSWzabbix-agent
/opt/csw/bin/zabbix_sender=/opt/csw/bin/isaexec l none CSWzabbix-agent
/opt/csw/sbin/sparcv8plus/zabbix_agent f none 0755 root bin 432756 17550 1340696530 CSWzabbix-agent
/opt/csw/sbin/sparcv8plus/zabbix_agentd f none 0755 root bin 497272 34563 1340696530 CSWzabbix-agent
/opt/csw/sbin/sparcv9 d none 0755 root bin CSWzabbix-agent
/opt/csw/sbin/sparcv9/zabbix_agent f none 0755 root bin 483816 12088 1340696534 CSWzabbix-agent
/opt/csw/sbin/sparcv9/zabbix_agentd f none 0755 root bin 554752 37902 1340696534 CSWzabbix-agent
/opt/csw/sbin/zabbix_agent=/opt/csw/bin/isaexec l none CSWzabbix-agent
/opt/csw/sbin/zabbix_agentd=/opt/csw/bin/isaexec l none CSWzabbix-agent
/opt/csw/share/doc/zabbix_agent d none 0755 root bin CSWzabbix-agent
/opt/csw/share/doc/zabbix_agent/license f none 0644 root bin 17991 30402 1340697025 CSWzabbix-agent
/opt/csw/share/man/man1 d none 0755 root bin CSWpkgutil CSWzabbix-agent
/opt/csw/share/man/man1/zabbix_get.1 f none 0644 root bin 997 15578 1340696530 CSWzabbix-agent
/opt/csw/share/man/man1/zabbix_sender.1 f none 0644 root bin 3274 22681 1340696530 CSWzabbix-agent
/opt/csw/share/man/man8 d none 0755 root bin CSWzabbix-agent
/opt/csw/share/man/man8/zabbix_agentd.8 f none 0644 root bin 911 10795 1340696530 CSWzabbix-agent
