autoclose problems after a period of time
  • BartTechne
    • Jan 2019
    • 15
    I have a trigger that hits every time a success backup gets written in the event log (checks every 1 minute as a test)
    {HOST-ACRONIS:eventlog[Application,,,Acronis Backup and Recovery,1,,skip].nodata(86400)}=0 and
    {HOST-Acronis:eventlog[Application,,,Acronis Backup and Recovery,1,,skip].logseverity()}=1
    I have made a Recovery expression :
    {HOST-Acronis:eventlog[Application,,,Acronis Backup and Recovery,1,,skip].nodata(40000)}=1
    It does not auto close the problems.
    Is theire a way to do this ? I searched the forums but did not find a definite soltiuon
  • nneka
    • Jun 2011
    • 9
    i don't undestand what you wanna do :
    {HOST-ACRONIS:eventlog[Application,,,Acronis Backup and Recovery,1,,skip].nodata(86400)}=0 => Why a 1 day nodata ??
    {HOST-Acronis:eventlog[Application,,,Acronis Backup and Recovery,1,,skip].logseverity()}=1 => Why this check ?
    you could try :
    {HOST-Acronis:eventlog[Application,,,Acronis Backup and Recovery,1,,skip].nodata(10)}=0
    with this method , you will have a alert when they are a new entry in your eventlog (matching acronis..) ...and after 10 minutes , you alert will be closed
    no recovery expression needed
    • BartTechne
      • Jan 2019
      • 15
      {HOST-Acronis:eventlog[Application,,,Acronis Backup and Recovery,1,,skip].logseverity()}=1 => To check if theire is an ew Information log entry in the Event log -> Backup Succes for example
      so i changed it now to
      Ill try and do this
      • BartTechne
        • Jan 2019
        • 15
        Problem has indeed been created but not autoclosed
        {Acronis:eventlog[Application,,,Acronis Backup and Recovery,1,,skip].nodata(10)}=0
        • nneka
          • Jun 2011
          • 9
          The problem will autoclosed if you not receive data (no entry in the event log) during 10 minutes ,
          checl if you contniue to receive data after the creation of incident
          • BartTechne
            • Jan 2019
            • 15
            {Acronis:eventlog[Application,Event 0x900001: Error code: 12,,Acronis Backup and Recovery,1,,skip].nodata(10)}=0
            last entry at 23.30.59 then the trigger went off. But after that no closure
            • BartTechne
              • Jan 2019
              • 15
              @nneka:
              tried this with 100 as trigger. It is specified in seconds according to the documentation. But still... no closure. Theire is no date coming in for the last 10 hours
              • josoko
                • Feb 2021
                • 25
                BartTechne
                I was faced also to this problem, of how to autoclose events in Zabbix. I solved my problem with a Webhook similar related to this Zabbix blog:
                - https://blog.zabbix.com/close-proble...bix-api/12461/
                It's the best way to that. Just doing some actions, and if it's done, the event will be closed.
                • Zablab
                  • Jan 2022
                  • 28
                  Seems like a simple thing but I'm also having this issue. We have an information trigger configured to notify us of site Version changes. We'd like to auto close these after 7 days and I am not having luck with it.
                  Trigger expression:
                  last(/site/site.version_number,#1) <> last(/site/site.version_number,#2)
                  Example of a recovery expression I've tried that doesn't work, but the idea would be to close it after 7 days if the version doesn't change:
                  nodata(/site/site/site.version_number,604800)=1
                  • Zablab
                    Zablab commented
                    So this cleared out all the problems older than 7 days, I do have pre-processing set to discard unchanged with heartbeat and should only get a value if the site updates in my scenario.
                    nodata(/site/site.version_number,7d)=0
                  Basics...
                  Recovery expression is ADDITIONAL condition, that has to be true for trigger to become false AFTER trigger condition is already turned false.
                  So if you compare last 2 values and also have recovery condition of "no data for one week", then you really should not have any data coming in during that week. But I assume you check it more often, like once a day... So recovery never becomes true and you whole trigger stays in problem state...
