I am running an ssh check on several remote Linux machines via a Zabbix proxy which all work HOWEVER on Redhat/Centos servers I get the prompt returned in the Last Value i.e. the command I am running is ps -A | grep mysqld | wc -l and I get the return value of ]0;Ida.c972
The 2 on the end is the value I am expecting but the stuff before it is the prompt. For some reason the client has changed the prompt in the .bashrc file so I can't interfere with that. The bit in the .bashrc file that change the prompt is below
hostname=`hostname`".c97"
PS1="\e[0;32m[\u@\h .c97 \w] \e[m \n[\W]$ "
bash -c "echo -ne '\033]0;$hostname\007'"
All the other Linux servers do this but if they are not Redhat/Centos they work fine.
I have spent days trying to resolve this but I can't.
I tried to use the trigger value to only use the last character of the text string i.e. the 2 but I can't get that to work either.
Any help would be gratefully received.
No I can't install the Zabbix Agent as much as I would like too.
My Zabbix Server 2.4 and Proxy 2.4 are both running Centos 6.5.
