log monitor
  • vnline
    • Oct 2011
    • 18
    log monitor
    zabbix_agent log:
    18901:20140425:101125.856 In process_value() key:'Zabbix Server:log[/var/log/sms.log]' value:'2014-04-25 10:11:11 request result code:200 MP:xxxxxx Object:#RECOVER: xxxx IP:192.168.16.2
    47 Content:Load Average was too high on xxxx is OK'
    18901:20140425:101125.856 In send_buffer() host:'127.0.0.1' port:10051 values:1/100
    18901:20140425:101125.856 JSON before sending [{
    "request":"agent data",
    "data":[
    "host":"Zabbix Server",
    "key":"log[\/var\/log\/sms.log]",
    "value":"2014-04-25 10:11:11 request result code:200\t MP:xxxxxxxx \t Object:#RECOVER: xxxx IP:192.168.16.247\t Content:Load Average was too high on xxxx is OK",
    "lastlogsize":1773292,
    "clock":1398391885,
    "ns":856265440}],
    "clock":1398391885,
    "ns":856596950}]
    18901:20140425:101125.857 JSON back [{
    "response":"success",
    "info":"processed: 0; failed: 1; total: 1; seconds spent: 0.000086"}]
    18901:20140425:101125.857 In check_response() response:'{
    "info":"processed: 0; failed: 1; total: 1; seconds spent: 0.000086"}'
    18901:20140425:101125.857 info from server: 'processed: 0; failed: 1; total: 1; seconds spent: 0.000086'
    18901:20140425:101125.857 End of check_response():SUCCEED
    18901:20140425:101125.857 OK
    18901:20140425:101125.858 End of send_buffer():SUCCEED
    18901:20140425:101125.858 buffer: new element 0
    18901:20140425:101125.858 End of process_value():SUCCEED
    18901:20140425:101125.858 In process_value() key:'Zabbix Server:log[/var/log/sms.log]' value:'2014-04-25 10:11:11 request result code:200 MP:1xxxxxxxx Object:#RECOVER: xxxxxx IP:192.168.16.2
    47 Content:Load Average was too high on xxxxx is OK'
    18901:20140425:101125.858 In send_buffer() host:'127.0.0.1' port:10051 values:1/100
    18901:20140425:101125.858 Will not send now. Now 1398391885 lastsent 1398391885 < 5
    Is something wrong?
    item config:
    item status:
    log permission:
    zabbix user can read and write the log file
    [root@xxx log]# ls -al /var/log/sms.log
    -rw-r--r--. 1 zabbix zabbix 1775864 Apr 25 10:11 /var/log/sms.log
    pls help,thanks!
  • aib
    • Jan 2014
    • 1615
    Check the error message from balloon over red cross.
    Check Monitoring -> Latest Data
    Check zabbix-server.log
    Sincerely yours,
    Aleksey
