I am trying to monitor a Corinex High Density Coax Head-End.
This is a central unit that connects a number of Coax modems.
I want to get the list of connections from the device.
the mac addresses, the uplink and downlink speeds.
There is the option of using telnet.
Whenever you connect with a normal telnet session, it logs right into the user prompt and with a /info command you get a table with all the required data.
However, when i use telnet-agent on zabbix, it becomes unsupported with the error " No Login Prompt"
Is there a way to make zabbix use telnet without logging in?
Another option is logging in to the web interface.
Here it requires a password and the required data is shown.
In the website source its displayed like this:
What would be the best way forward?
Hope someone can help me, thnx
var pcp=new Array('10','12','14','15','11','13','9');
var pcma=new Array('000xxxxx6E0B','000xxxxx6EA6','000xxxxx6EA7','000xxxxx6EA8','000xxxxx6EA9','000Bxxxx7389','000xxxxx738A');
var pcptx=new Array('166 Mbps','171 Mbps','165 Mbps','151 Mbps','166 Mbps','162 Mbps','165 Mbps');
var pcprx=new Array('162 Mbps','153 Mbps','135 Mbps','33 Mbps','132 Mbps','144 Mbps','82 Mbps');
var pcbs=new Array('Enabled','Enabled','Enabled','Enabled','Enabled','Enabled','Enabled');
