Sorry, I'm new to Zabbix Network Monitoring. I have a medium size network with VPN to remote sites that I want to monitor also. What type of server would I need to monitor 500 hosts? I'm trying to install Zabbix on a VM server. What is the current version of Zabbix? I have a Zabbix created, and I current using Zabbix 4.0.0rc3.
Zabbix Help
Tags: None
zabbix server: 8 cpu cores, +8GB RAM
zabbix server DB backend: +8cpu cores, +64GB RAM, +1TB (at least) SATA SSD
web frontend: +4 cpu cores, +8GB RAM
Many depends on on what you are going to monitor on those hosts which affects avg number of metrics per host (number of monitored hosts is less important)http://uk.linkedin.com/pub/tomasz-k%...zko/6/940/430/
My zabbix templates https://github.com/kloczek/zabbix-templates -
