Eventlog alert not working
  • richard1982
    • Jan 2019
    Running Zabbix 2.4
    I have been unable to properly configure an email alert when a Windows event occurs and need help. I really need help.
    I created an item as such:
    eventlog[System,,"Warning",,1340,,] here is the picture: https://i.imgur.com/7KHUmNv.jpg
    I then created a trigger from that item as such:
    {net-dhcp-d02.main.sjcd.edu:eventlog[System,,"Warning",,1340,,].logeventid()}=0 here is the picture: https://i.imgur.com/QaTUayl.jpg
    I then configured an Action to email me when this Event happens. What am I doing wrong? Please help.
    This System Eventlog happens like every 30 seconds so I know the event is occurring. The Server the agent is trying to read the Eventlog from is a Windows Server 2016.
    Here is my config file:
    # This is a config file for the Zabbix agent daemon (Windows)
    # To get more information about Zabbix, go to http://www.zabbix.com
    ### Option: LogFile
    # Name of log file.
    # If not set, Windows Event Log is used.
    # Mandatory: no
    # Default:
    # LogFile=
    LogFile=C:\zabbix_agents_2.4.1.win\Logs\zabbix_age ntd.log
    ### Option: LogFileSize
    # Maximum size of log file in MB.
    # 0 - disable automatic log rotation.
    # Mandatory: no
    # Range: 0-1024
    # Default:
    # LogFileSize=1
    ### Option: DebugLevel
    # Specifies debug level
    # 0 - basic information about starting and stopping of Zabbix processes
    # 1 - critical information
    # 2 - error information
    # 3 - warnings
    # 4 - for debugging (produces lots of information)
    # Mandatory: no
    # Range: 0-4
    # Default:
    #DebugLevel=4
    ### Option: SourceIP
    # Source IP address for outgoing connections.
    # Mandatory: no
    # Default:
    # SourceIP=
    ### Option: EnableRemoteCommands
    # Whether remote commands from Zabbix server are allowed.
    # 0 - not allowed
    # 1 - allowed
    # Mandatory: no
    # Default:
    # EnableRemoteCommands=0
    ### Option: LogRemoteCommands
    # Enable logging of executed shell commands as warnings.
    # 0 - disabled
    # 1 - enabled
    # Mandatory: no
    # Default:
    # LogRemoteCommands=0
    ##### Passive checks related
    ### Option: Server
    # List of comma delimited IP addresses (or hostnames) of Zabbix servers.
    # Incoming connections will be accepted only from the hosts listed here.
    # If IPv6 support is enabled then '127.0.0.1', '::127.0.0.1', '::ffff:127.0.0.1' are treated equally.
    # Mandatory: no
    # Default:
    # Server=
    Server=zabbix.test.org
    ### Option: ListenPort
    # Agent will listen on this port for connections from the server.
    # Mandatory: no
    # Range: 1024-32767
    # Default:
    # ListenPort=10050
    ### Option: ListenIP
    # List of comma delimited IP addresses that the agent should listen on.
    # First IP address is sent to Zabbix server if connecting to it to retrieve list of active checks.
    # Mandatory: no
    # Default:
    # ListenIP=0.0.0.0
    ### Option: StartAgents
    # Number of pre-forked instances of zabbix_agentd that process passive checks.
    # If set to 0, disables passive checks and the agent will not listen on any TCP port.
    # Mandatory: no
    # Range: 0-100
    # Default:
    # StartAgents=3
    ##### Active checks related
    ### Option: ServerActive
    # List of comma delimited IPort (or hostnameort) pairs of Zabbix servers for active checks.
    # If port is not specified, default port is used.
    # IPv6 addresses must be enclosed in square brackets if port for that host is specified.
    # If port is not specified, square brackets for IPv6 addresses are optional.
    # If this parameter is not specified, active checks are disabled.
    # Example: ServerActive=127.0.0.1:20051,zabbix.domain,[::1]:30051,::1,[12fc::1]
    # Mandatory: no
    # Default:
    # ServerActive=
    ServerActive=zabbix.test.org
    ### Option: Hostname
    # Unique, case sensitive hostname.
    # Required for active checks and must match hostname as configured on the server.
    # Value is acquired from HostnameItem if undefined.
    # Mandatory: no
    # Default:
    # Hostname=
    Hostname=NET-DHCP-D02
    ### Option: HostnameItem
    # Item used for generating Hostname if it is undefined. Ignored if Hostname is defined.
    # Does not support UserParameters or aliases.
    # Mandatory: no
    # Default:
    # HostnameItem=system.hostname
    ### Option: HostMetadata
    # Optional parameter that defines host metadata.
    # Host metadata is used at host auto-registration process.
    # An agent will issue an error and not start if the value is over limit of 255 characters.
    # If not defined, value will be acquired from HostMetadataItem.
    # Mandatory: no
    # Range: 0-255 characters
    # Default:
    # HostMetadata=
    ### Option: HostMetadataItem
    # Optional parameter that defines an item used for getting host metadata.
    # During an auto-registration request an agent will log a warning message if
    # the value returned by specified item is over limit of 255 characters.
    # This option is only used when HostMetadata is not defined.
    # Mandatory: no
    # Default:
    # HostMetadataItem=
    ### Option: RefreshActiveChecks
    # How often list of active checks is refreshed, in seconds.
    # Mandatory: no
    # Range: 60-3600
    # Default:
    RefreshActiveChecks=120
    ### Option: BufferSend
    # Do not keep data longer than N seconds in buffer.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # BufferSend=5
    ### Option: BufferSize
    # Maximum number of values in a memory buffer. The agent will send
    # all collected data to Zabbix server or Proxy if the buffer is full.
    # Mandatory: no
    # Range: 2-65535
    # Default:
    # BufferSize=100
    ### Option: MaxLinesPerSecond
    # Maximum number of new lines the agent will send per second to Zabbix Server
    # or Proxy processing 'log', 'logrt' and 'eventlog' active checks.
    # The provided value will be overridden by the parameter 'maxlines',
    # provided in 'log', 'logrt' or 'eventlog' item keys.
    # Mandatory: no
    # Range: 1-1000
    # Default:
    # MaxLinesPerSecond=100
    ############ ADVANCED PARAMETERS #################
    ### Option: Alias
    # Sets an alias for an item key. It can be used to substitute long and complex item key with a smaller and simpler one.
    # Multiple Alias parameters may be present. Multiple parameters with the same Alias key are not allowed.
    # Different Alias keys may reference the same item key.
    # For example, to retrieve paging file usage in percents from the server:
    # Alias=pg_usageerf_counter[\Paging File(_Total)\% Usage]
    # Now shorthand key pg_usage may be used to retrieve data.
    # Aliases can be used in HostMetadataItem but not in HostnameItem or PerfCounter parameters.
    # Mandatory: no
    # Range:
    # Default:
    ### Option: Timeout
    # Spend no more than Timeout seconds on processing
    # Mandatory: no
    # Range: 1-30
    # Default:
    # Timeout=3
    ### Option: PerfCounter
    # Syntax: <parameter_name>,"<perf_counter_path>",<period>
    # Defines new parameter <parameter_name> which is an average value for system performance counter <perf_counter_path> for the specified time period <period> (in seconds).
    # For example, if you wish to receive average number of processor interrupts per second for last minute, you can define new parameter "interrupts" as following:
    # PerfCounter = interrupts,"\Processor(0)\Interrupts/sec",60
    # Please note double quotes around performance counter path.
    # Samples for calculating average value will be taken every second.
    # You may run "typeperf -qx" to get list of all performance counters available in Windows.
    # Mandatory: no
    # Range:
    # Default:
    ### Option: Include
    # You may include individual files in the configuration file.
    # Mandatory: no
    # Default:
    # Include=
    # Include=c:\zabbix\zabbix_agentd.userparams.conf
    # Include=c:\zabbix\zabbix_agentd.conf.d\
    # Include=c:\zabbix\zabbix_agentd.conf.d\*.conf
    ### Option: UnsafeUserParameters
    # Allow all characters to be passed in arguments to user-defined parameters.
    # 0 - do not allow
    # 1 - allow
    # Mandatory: no
    # Range: 0-1
    # Default:
    # UnsafeUserParameters=0
    ### Option: UserParameter
    # User-defined parameter to monitor. There can be several user-defined parameters.
    # Format: UserParameter=<key>,<shell command>
    # Mandatory: no
    # Default:
    # UserParameter=
    UserParameter=windows.services,"C:\zabbix_agents_2 .4.1.win\file\services.exe"
  • richard1982
    • Jan 2019
    Bumping this message in hopes for help.
    • richard1982
      • Jan 2019
      Can someone help?
      • richard1982
        • Jan 2019
        • LenR
          • Sep 2009
          • 1010
          Are you getting any history for this item? Try removing the "Warning" option.
          • richard1982
            • Jan 2019
            History? Not sure what that means. I did remove the warning option and it didnt seem to do anything.
            • LenR
              • Sep 2009
              • 1010
              Host, latest data, is there any data collected? If not, the problem is in the item, if there is, then the problem is in the trigger or beyond. If no data, check the zabbix agent log on the windows system.
              • richard1982
                • Jan 2019
                NO data is being collected.
                The log doesn't give any helpful information.
