Logs monitoring
  • Tatiana
    • Jan 2019
    Logs monitoring
    I’m trying to configure log monitoring and working on a triggers setup. It seems to be working fine if I know what my regexp or str is, but I want to be notified about ANY new entries in my log file without specifying the string. Basically, I need a regexp for any string which will work with zabbix expression function. I tried to use (.*) and it doesn’t work as I expected.
    {Log Server:log[/var/log/zabbixls/messages].regexp(.*)}=1
    Thanks for any help…
  • Semiadmin
    • Oct 2014
    • 1626
    {Log Server:log[/var/log/zabbixls/messages].strlen()}>0
    • Tatiana
      • Jan 2019
      Thank you Semiadmin, but unfortunately .strlen()}>0 doesn't work for me either - the trigger doesn't change its state to "problem" with the new lines in the log file.
      I have other two triggers configured: ...they both work as expected - they trigger the problems and I receive emails...
      • colin88
        • Dec 2016
        • 13
        Do you still have the problem?
        Try
        {Log Server:log[/var/log/zabbixls/messages].regexp(\S+)}=1
        \S looks for any non-white space character, + means "one or more of that". This should ignore new lines in your log file.
        As a general tip for regex:
        Have a look at http://regex101.com. You can test your regular expressions and there is also a quick reference.
        • Tatiana
          • Jan 2019
          Thank you colin88. I think I found what my problem was. In a trigger setup I set "PROBLEM event generation mode" to "Single" and it didn't really work properly in my case, with "Multiple" mode - it seems to be working fine so far. I just still don't understated why this two worked fine with a "Single" mode:
          {Log Server:log[/var/log/zabbixls/messages].regexp(Starting)}=1
          {Log Server:log[/var/log/zabbixls/messages].str(error)}=1
          • dtalero798
            • Jan 2019
            Hi
            please a need help ,
            i create monitory log for this key log[/var/www/zabbix/SE_SAPASE.log,"cpu"],
            desire is that when the field is modified the action generates me for example, if the field cpu the file changes from 27 to 100, nowadays I have this launcher but I do not believe that it expires with the conditions that I need example "{192.168.50.180:log [/var/www/zabbix/SE_SAPASE.log, "cpu"] .diff (0)} <=20"
