Zabbix Integration to Pagerduty
  • amalkamal
    • Jan 2019
    Hi Zabbix Support,
    I'm Amal,
    I have followed below document and successfully configured.
    But when trigger alert i found this error:
    Then i checked folder on ubuntu Server 18.04.LTS it showing empty folder. No Alert script. I created alert script but it not showing there.
    Please appreciate your help.
    Thank you,
    Amal!
  • Atsushi
    • Aug 2013
    • 2028
    By default, place notification scripts in /usr/lib/zabbix/alertscripts.
    It is written on the page of the referenced URL, but you will need to create a link to pd-zabbix in this directory.
    ex.
    sudo ln -s /usr/share/pdagent-integrations/bin/pd-zabbix /usr/lib/zabbix/alertscripts
