Can ZabbixAgent Docker Container monitoring host OS services?
It's a patched version of the agent that can monitor the docker host. I use it with coreos to monitor coreos process and other containers on the same host.
Is it possible to monitor the host of zabbix agent, from a zabbix server which is installed on a separate VM? or Zabbix server must be running within a container?
