Get auditlog from API
  • YiNHo
    • May 2014
    I was wondering if is there a way to get the information that is showed at the "Audit" section. I found no operation to do that in Zabbix API.
    Do you know if it is possible?
    What is the best (or clean) workaround to get the last changes applied on zabbix configuration? (I mean hosts, hostgroups, triggers, etc...)
    Regards.
  • gareth.brown
    • May 2015
    There is nothing in the API documentation that I can find
