VMWare Error
  • mshpolar
    • Feb 2019
    VMWare Error
    Hi there,
    Has anyone run across this before on Zabbix 4.0?
    1053:20190206:165700.534 Error of query maxQueryMetrics: 'config.vpxd.stats.maxQueryMetrics' is invalid or exceeds the maximum number of characters permitted..
    If so would you please share if you ever resolved it?
  • Atsushi
    • Aug 2013
    • 2028
    Is not it a bug fixed in 4.0.2?
    Please tell me the detailed version of Zabbix you are using.
    • mshpolar
      • Feb 2019
      Ah yes, its Zabbix 4.0.3
      • StevenBrs
        • Sep 2015
        • 11
        Hi there,
        Did you ever find a solution ?
        I'm running Zabbix 4.0.12 on centOS7, monitoring vCenter 6.7, and I'm seeing this error in /var/log/zabbix_server.log:
        100422:20190916:132954.966 Error of query maxQueryMetrics: 'config.vpxd.stats.maxQueryMetrics' is invalid or exceeds the maximum number of characters permitted..
        I tried setting config.vpxd.stats.MaxQueryMetrics = -1 on the vCenter appliance, and editing the /usr/lib/vmware-perfcharts/tc-instance/webapps/statsreport/WEB-INF/web.xml file setting maxQuerySize=0
        but the error still occurs.
        So, I was wondering
        1. how I can get rid of this error
        2. What is the impact of this error ? What info am I missing ?
        Thanks in advance
        Steven
        • GustavGustav
          • Dec 2019
          I have the same issue here. Also monitoring vcenter 6.7
          Problem occured first on Zabbix 4.0.14 LTS (the first version that I ever installed, not sure about prior versions), yesterday I upgraded Zabbix to the latest version 4.4.4, but the issue is still occuring. OS is Debian 10 Buster, Zabbix is installed from official .deb repository.
          I am aware of these related bug reports:
          And this vmware documentation:
          Performance charts are empty and displays the error: Request processing is restricted by administrator
          That mention that the vcenter config.vpxd.stats.maxQueryMetrics value should be set to some other value than 0 or -1 to fix this.
          Did that, now that value is set to 256. Also restarted the corresponding VMware Performance Charts Service, but Zabbix is still showing this error every minute in the logs.
          How can this be further narrowed down or debugged?
