ZBX maps: connecting line color
  • steveboyson
    • Jul 2013
    • 582
    Is there by any chance the possibility to define the color of a link between two icons based on a item value?
    I know this can be done via a trigger value, but I want it to be an item value.
    Why? Because if I define a trigger, it corresponds to a somewhat "PROBLEM" state which does not apply in my case.
    Example: I have two hosts in a DRBD/CRM/Pacemaker cluster, one is master and one is slave. In the corresponding map, I'd like to have a solid rectangle around the current master and a dashed rectange (both build of four 1x1 white pixels and links between) around the current slave.
    So using triggers is not possible as there is always one master and one slave - in other cases I have triggers defined already if the cluster is broken.
    Am I missing something or can't that be done?
    Any hints are welcome, thank you!
