Import initial schema and data error,perhaps utf8
  • ggggsc
    • Feb 2019
    • 23
    I just set up a new zabbix server and mysql database,on two different hosts.
    I have copied the create.sql.gz file to db hosts,however ,when i run zcat on db hosts, there's an error:
    [root@zabbix-db ~]# zcat /usr/local/create.sql.gz | mysql -uzabbix -p zabbix
    Enter password:
    ERROR 1366 (HY000) at line 2313: Incorrect string value: '\xE2\x80\x99s i...' for column 'description' at row 1
    I do create the zabbix database using utf8, I dropped the table and recreated it ,still don't work.
    create database zabbix character set utf8 collate utf8_bin;
    what can I do , what character set should I use?
  • Atsushi
    • Aug 2013
    • 2028
    It seems that the default character code used by MySQL client in your environment is not utf8. Please connect with the mysql command and execute as follows and check whether character_set_client etc is utf8.
    > show variables like 'char%';
    | Variable_name            | Value                      |
    | character_set_client     | utf8                       |
    | character_set_connection | utf8                       |
    | character_set_database   | utf8                       |
    | character_set_filesystem | binary                     |
    | character_set_results    | utf8                       |
    | character_set_server     | utf8                       |
    | character_set_system     | utf8                       |
    | character_sets_dir       | /usr/share/mysql/charsets/ |
    8 rows in set (0.00 sec)
    Try setting the default character set in the my.cnf file, or add the option "--default-character-set=utf8" when executing the mysql command.
    I have added the following setting to the mysqld section of /etc/my.cnf.d/ server.cnf when I use Mariadb of OS standard in CentOS 7.
    [mysqld]
    character-set-server = utf8
    collation-server     = utf8_bin
    skip-character-set-client-handshake
    innodb_file_per_table
    • ggggsc
      ggggsc commented
      Thanks a lots for your help, it works now!
      In addition,
      my platform is centos7 & mysql8.0, the configure file located in /etc/my.cnf
