/usr/lib/zabbix/externalscripts/zbxwmi: [2] No such file or directory
  • EmmBee
    • Jan 2019
    • 23
    i have a problem, i tried to use python script + template from github https://github.com/13hakta/zbxwmi for reading microsoft servers data by WMI.
    I stucked on some problem now, as you can see in attachment script item is returning error: " /usr/lib/zabbix/externalscripts/zbxwmi: [2] No such file or directory " .
    What can be wrong do you have some experiences with this?
  • Atsushi
    • Aug 2013
    • 2028
    Have you placed zbxwmi in the /usr/lib/zabbix/externalscripts directory? Please check the procedure written in README.md again.
    • EmmBee
      EmmBee commented
      Yes path is correct, file is there.
    • Atsushi
      Atsushi commented
      Did you check the permissions of the file?
      Please show the execution result of the following command.
      # ls -l /usr/lib/zabbix/externalscripts/zbxwmi
    • EmmBee
      EmmBee commented
      root@srv-zabbix:/# ls -l /usr/lib/zabbix/externalscripts/zbxwmi
      -rwxr-xr-- 1 zabbix zabbix 6448 Ășno 15 07:59 /usr/lib/zabbix/externalscripts/zbxwmi
