Zabbix Extra (Everyz) and Zabbix 4.0
  • bjarte-af
    • Feb 2019
    I have used EveryZ with Zabbix for some time and it has been very good. Now we upgraded Zabbix to version 4 but cannot get it to work after that. The frontend just give me a blank page after installing EveryZ. Du you have any suggestions?
    Alternatively any suggestions for georeferenced map to show locations of sites/nodes?
  • Hernandes Martins
    • Apr 2011
    • 901
    The Every-Z is not ready to use with zabbix 4. The developer is doing the updates. The project is very important and need financial support to finish update.
    look the group on telegram: https://t.me/everyz
    Regards
    __
    Att.
    Skype: hernandss
    Telegram: @MrHernandes
    Español
    Português
