Prevent item delete "The item is not discovered anymore and will be deleted"
  • Oigres
    • Feb 2019
    Hello.
    Im new with zabbix and i have a question.
    I use auto discovery and now i made some changes and some items are not discovered anymore.
    I have a menssage in this items "The item is not discovered anymore and will be deleted", but i want to keep the data from this items to check the graphs.
    Any way to prevent this?
    Thank you.
  • Hernandes Martins
    • Apr 2011
    • 901
    Maybe , Can you change the parameter " Keep lost resources period " in Discovery Rule, but I think not so good practices to storage data.
    __
    Att.
    Skype: hernandss
    Telegram: @MrHernandes
    Español
    Português
    • Oigres
      • Feb 2019
      Thank you for your reply.
      I just want to keep some items, not all of them.
      • charannaik
        • Dec 2014
        The only alternative, (depending on the number discovered items / hosts) is to delete the unwanted items manually after increasing the "Keep lost resources period" value. Again, increasing the "Keep lost resource period" is not a good practice as Hernandes Martins already mentioned.
        • Oigres
          • Feb 2019
          I was thinking on doing that.
          Whats is the best pratices in this case?
          • monoterrible
            • Feb 2024
            Sorry if what I propose is stupid:
            Wouldn't running the discoveries associated with the host again resolve the issue? Thank you for the availability and good predisposition​
            • PeterZielony
              • Nov 2022
              • 146
              No..He was asking to keep items that are no longer discovered by LLD indefinitely. Running discovery again would just discover what is available - items created before(by LLD) will be deleted after time specified in "Keep lost resource period" in LLD.
              Hiring in the UK? Drop a message
              • monoterrible
                monoterrible commented
                muchas gracias, por la respuesta.
            • dimir
              Zabbix developer
              • Apr 2011
              • 1080
              In theory (haven't tested) you should be able to keep that item if you change the lastcheck field in the item_discovery table.
              Find out the itemid of your item (e. g. go to Configuration section, select host, items, right-click your item and Inspect the HTML code, it will be in data-itemid attribute), then go to your database and execute:
              update item_discovery set lastcheck=unix_timestamp('2038-01-01') where itemid=<ITEMID>;
