Running scripts (when clicked on hosts)on Different Servers instead of zabbix server.
  • zabbixfk
    • Jun 2013
    • 256
    Hello All,
    Is there any way to trigger scripts ( Administration-> Scripts ) from different server say proxy server instead of zabbix server/agent?
    The reason for this question was, i have a proxy server for which some range of hosts are connecting, and i wanted to run traceroute to hosts from proxy server. As of now i don't see any option to sepcify the same.
    Any pointers are greatly helpful.
  • dan_cytexone
    • Dec 2008
    • 61
    Is it possible to run Custom scripts to manage hosts via proxies?
    If so how do you do this?
    • Firm
      • Dec 2009
      • 342
      {PROXY.NAME} macro is supported in "Trigger-based notifications and commands". So you can provide it to server script which may execute remote command on proxy via ssh.
      • dan_cytexone
        • Dec 2008
        • 61
        Can you please give a specific example on how to do this? ie Where to place {proxy.name} and perhaps an example screenshot or syntax?
        Thank you so much for your help
        • Firm
          • Dec 2009
          • 342
          "Commands" field should looks like this:
          ssh {PROXY.NAME} traceroute {HOST.CONN}
          Of course, you have to configure public key access under zabbix user to proxy host.
          • dan_cytexone
            • Dec 2008
            • 61
            Can you explain what you mean by public key access? I just tested this with a super admin and please see error below
            Command :
            ssh {PROXY.NAME} /bin/ping -c 3 {HOST.CONN} 2>&1
            Error Received :
            ssh: Could not resolve hostname {proxy.name}: Name or service not known
            • dan_cytexone
              • Dec 2008
              • 61
              Hi Firm
              Wanted to follow up to see if you knew how to solve this?
              Thanks!
              Dan
              • Firm
                • Dec 2009
                • 342
                It seems that {PROXY.NAME} is not populated if script is running on server side. Need to investigate further.
                • dan_cytexone
                  • Dec 2008
                  • 61
                  Thanks, please let me know or if anyone else has any suggestions.
                  • dan_cytexone
                    • Dec 2008
                    • 61
                    Seems like {PROXY.NAME} doesn't work anywhere in the system.
                    • dan_cytexone
                      • Dec 2008
                      • 61
                      Rebump on this message
