Monitor file system that is missing
  • marques.mariana
    • Feb 2019
    is there a way to monitor and have a trigger on a missing filesystem ?
    Usualy when that happens the item goes not supported and the trigger with the .nodata() function doesn’t work...
    Any suggestions?
    Thanks!
  • LenR
    • Sep 2009
    • 1011
    vfs.file.exists should do it
    • marques.mariana
      • Feb 2019
      Thank you very much! It worked
