Zabbix 4.0.2 + openipmi 2.0.22-1
  • wylde
    • Sep 2016
    • 10
    Zabbix is randomly getting disconnected from BMC for some reason.. It will reconnect usually within 5 minutes but during this time the blades appear to be offline and would alert based on this critical event. The network path is very simple .. it goes through 1 juniper switch which is not reporting any connectivity issues. I've noticed some discussion about openipmi developmers not really being that forthcoming with changes to their code and it has caused problems with Zabbix code in the past. So i'm curious if anyone else is experiencing this issue. I disabled all other items for the ipmi template. Only the power status check is currently enabled. Only 1 host is being queried for ipmi related items. I am querying against a supermicro x10sdd-f board running IPMI Revision 2.0 code
    Connectivity is fine..
    5000 packets transmitted, 5000 received, 0% packet loss, time 5117509ms
    rtt min/avg/max/mdev = 0.228/0.600/40.788/2.650 ms
    root@zab-web-1:~# dpkg -l | grep openipmi
    ii libopenipmi0 2.0.22-1.1ubuntu2.1 amd64 Intelligent Platform Management Interface - runtime
    ii openipmi 2.0.22-1.1ubuntu2.1 amd64 Intelligent Platform Management Interface (for servers)
    ii zabbix-agent 1:4.0.4-1+bionic amd64 Zabbix network monitoring solution - agent
    ii zabbix-frontend-php 1:4.0.4-1+bionic all Zabbix network monitoring solution - PHP front-end
    ii zabbix-release 1:4.0-2+bionic all Zabbix official repository configuration
    ii zabbix-server-mysql 1:4.0.4-1+bionic amd64 Zabbix network monitoring solution - server (MySQL)
    zabbix_server.log
    18335:20190221:144611.606 WARN: 0 0 ipmi_lan.c(lost_connection): Connection 0 to the BMC is down
    18335:20190221:144611.606 SEVR: 0 0 ipmi_lan.c(lost_connection): All connections to the BMC are down
    18335:20190221:144611.606 EINF: 0(23.1).power chassis.c(chassis_power_get_cb): Received IPMI error: ff ..... i've also seen error: c3
    18335:20190221:144611.609 control 'power@[x.x.x.x]:623' deleted
    zabbix_server.conf
    LogFile=/var/log/zabbix/zabbix_server.log
    LogFileSize=0
    DebugLevel=4
    PidFile=/var/run/zabbix/zabbix_server.pid
    SocketDir=/var/run/zabbix
    DBName=zabbix
    DBUser=zabbix
    DBPassword=mysqlpassword
    StartIPMIPollers=3
    StartPollersUnreachable=1
    SNMPTrapperFile=/var/log/snmptrap/snmptrap.log
    Timeout=4
    AlertScriptsPath=/usr/lib/zabbix/alertscripts
    ExternalScripts=/usr/lib/zabbix/externalscripts
    FpingLocation=/usr/bin/fping
    Fping6Location=/usr/bin/fping6
    LogSlowQueries=3000
