Separate Installation zabbix
  • Urahara
    • Jan 2019
    • 19
    Hello everyone,
    I was searching if I could possibly separate the C part of the PHP part of zabbix.
    Thanks you in advance.
  • LenR
    • Sep 2009
    • 1007
    ? zabbix_server on one server and zabbix_web on a separate server? Yes, even multiple zabbix_web servers if you want.
    • Urahara
      • Jan 2019
      • 19
      Yes, I want to separate PHP and C part. How could I do it ?
      • Atsushi
        Atsushi commented
        For example, prepare two servers.
        On the first machine, install the zabbix-server-mysql package. On the second machine, install the zabbix-web-mysql package. It is possible to prepare a different server on the database on either server.
        It is important to be able to access a common database from Zabbix server process running on the first server and httpd(php) running on the second server.
    • Urahara
      • Jan 2019
      • 19
      And how to do it with the source files ?
      • barton21
        • Feb 2019
        how to do it with source files?
        • Urahara
          • Jan 2019
          • 19
          Yes, because I want to use alpine and the latest version on alpine in package is 3.4 so I can only install from source files
