Automatic switch monitoring
  • benoitmartin
    • Oct 2018
    I use a discovery to find the switches using an OID with snmpv2. Now via the action I would like to be able to automatically add the discovered switches according to their model. If for example the switch and type Mellanox I would like to apply the template Mellanox. Can you help me.
    Thank you!
