Zabbix from Ubuntu 14.04 repositories was used (I tried to test web UI from latest version and it's has same problem). No errors was reported while setup. But I can access web UI only as guest. Error form displayed with options to login and view dashboard as guest. The problem is login option doesn't show login form, instead it's lead to same error messageā¦
Part of Nginx config:
and "avi9526/php-fpm"
location "/zabbix/"
index index.php index.html;
try_files $uri $uri/ /zabbix/index.php;
alias "/usr/share/zabbix/";
auth_basic "Authorization required to access Zabbix";
auth_basic_user_file htpasswd;
location ~* "/zabbix/(api|conf|include)((/.*)?)$"
deny all;
return 404;
location ~ "^/zabbix/(.+?\.php)(/.*)?$"
root "/usr/share/zabbix/";
try_files $1 $uri $uri/ /zabbix/index.php;
rewrite "^/zabbix/(.+?\.php)(/.*)?$" /$1$2 break;
# PHP-FPM Settings
include avi9526/php-fpm;
fastcgi_pass php-fpm; include fastcgi_params; fastcgi_split_path_info ^(.+?\.php)(/.*)?$; fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name; fastcgi_param PATH_TRANSLATED $document_root$fastcgi_script_name; set $path_info $fastcgi_path_info; fastcgi_param PATH_INFO $path_info; fastcgi_param SERVER_ADMIN [email protected]; fastcgi_param SERVER_SIGNATURE nginx/$nginx_version; fastcgi_index index.php;
