Setting up a Trigger for Idle Users logged into Servers
  • tehrev
    • Feb 2019
    I'm really new to Zabbix and am looking to setup a trigger that will warn me when a User has been logged into one of my servers and has been idle for over 15 minutes. Is there a way to do that? Currently I have an item that just shows me the users who are currently logged in. It looks like this
    The output looks like this
    So is there anyway to alert me when Idle time is over 15 minutes as you can see in the example above the user is logged in over 24 minutes idle.
    Any help would be greatly appreciated.
    Thanks.
  • poxeron
    • Sep 2020
    • 52
    Did you resolve this issue ?
    • tehrev
      • Feb 2019
      No I have not
      • poxeron
        poxeron commented
        I will share with you my way.
    • poxeron
      • Sep 2020
      • 52
      1) PowerShell scripts as USER PARAM. my called "user_idle_time.ps1"
      function Get-QUserInfo
      [CmdletBinding()]
      Param (
      [Parameter ()]
      [string[]]
      $ComputerName = $env:COMPUTERNAME
      begin
      $Header = 'UserName','SessionName','ID','State','IdleTime',' LogonTime'
      $No_Connection = '-- No Connection --'
      process
      foreach ($CN_Item in $ComputerName)
      if (Test-Connection -ComputerName $CN_Item -Count 1 -Quiet)
      quser /server:$CN_Item |
      Select-Object -Skip 1 |
      ForEach-Object {($_ -replace '\s{2,}', ',').Trim()} |
      ConvertFrom-Csv -Header $Header |
      ForEach-Object {
      if ($_.IdleTime -eq 'none')
      $IdleTime = $Null
      else
      $IdleTime = $_.IdleTime
      [PSCustomObject]@{
      ComputerName = $CN_Item
      UserName = $_.UserName
      SessionName = $_.SessionName
      ID = $_.ID
      State = $_.State
      IdleTime =$IdleTime
      LogonTime = [datetime]$_.LogonTime
      else
      [PSCustomObject]@{
      UserName = $No_Connection
      SessionName = $No_Connection
      ID = $No_Connection
      State = $No_Connection
      IdleTime = $No_Connection
      LogonTime = $No_Connection
      } # end >> foreach ($CN_Item in $ComputerName)
      } # end >> process {}
      end {}
      } # end >> function Get-QUserInfo
      Get-QUserInfo -ComputerName LocalHost
      • poxeron
        • Sep 2020
        • 52
ID:	421530 Click image for larger version
        2) add route to zabbix config file
        UserParameter=user.idle.time[*],powershell -NoP -NonI -executionpolicy bypass "& {&'PATH:\TO\Scripts\user_idle_time.ps1'}"
        3) create Item
        • poxeron
          • Sep 2020
          • 52
ID:	421533 4) create separate dependence items for login, computer, idle time
          • poxeron
            • Sep 2020
            • 52
ID:	421535 Click image for larger version
            5) like on pictures
            • poxeron
              • Sep 2020
              • 52
ID:	421538 6) create trigger. I could not fine where in PowerShell script i get the (.) but i use it in trigger.
              • poxeron
                • Sep 2020
                • 52
                7) Enjoy
ID:	421541 Click image for larger version
