System Status in Zabbix 4
  • markl
    • Apr 2008
    • 62
    In Zabbix pre 4, there was a System Status screen that showed Host Group, Disaster, High, Medium, Low, Information, Not Classified in one screen and any alerts would show up against the Host Group. In Zabbix 4, that option doesn't appear to be there and I'm wondering if I'm doing something wrong or if it genuinely isn't there any more? Its a handy screen to have as we have a monitor on the wall for multiple customers and its a quick indicator to see if there are any issues against a particular one of them.
  • Atsushi
    • Aug 2013
    • 2028
    Can not you get the view you want using the "Problem by serverity" widget on the dashboard?
