How to Check if the error has XX minutes of age.
  • charolaraenmexico
    • May 2014
    HI, i am new to zabbix and i want to check if the error has an age of 3 or more minutes untill zabbix alerts me sending an email.
    It is the same if i could check if the last 3 errors are not 0 untill zabbix alerts me sending an email.
    Thanks in advance.
    Diego
  • Navern
    • May 2013
    • 33
    Example
    you have status value: 1(Up), 0(Down).
    You want to send notification when status was down for last 3 minutes(180 seconds)
    Use function value.max(180)=0. It means that maximum value within this time(3 minutes) was 0.
    I also want to add that this functions impacts you performance. max(86400) is more worse than max(30).
    More on this with good examples: https://www.zabbix.com/documentation...ers/expression
    • charolaraenmexico
      • May 2014
      It works!
      Thank you Navern, it works perfectly.
