ldap simple check fails in 4.0 -worked fine in 3.4
  • albatrosdk
    • Mar 2018
    • 12
    Quite odd, I copied the database into a new 4.0.5 installation and everything is working fine except that it says that LDAP is not running on a LDAP server we have. I know for a fact that the server hasn't been touched, so what's going on?
    This is the expression used in the trigger: {Template App LDAP Service:net.tcp.service[ldap].max(#3)}=0
    There are no macros defined or anything else. If I ldapsearch to the LDAP server on port 389 it replies.:
    [root@pc543 ~]# ldapsearch -x -h ldapserver.nodomain.com
    # extended LDIF
    # LDAPv3
    # base <> (default) with scope subtree
    # filter: (objectclass=*)
    # requesting: ALL
    # search result
    search: 2
    result: 32 No such object
    # numResponses: 1
    [root@pc543 ~]#
    So, has anything changed in the ldap simple check?
    /A
  • albatrosdk
    • Mar 2018
    • 12
    Fixed. It was SELinux that blocked zabbix-server from accessing the network:
    [root@pc543 zabbix]# getsebool -a |grep zabbix
    httpd_can_connect_zabbix --> on
    zabbix_can_network --> off
    zabbix_run_sudo --> off
    [root@pc543 zabbix]# setsebool zabbix_can_network on
    zabbix_can_network --> on
    /A
