Installed Zabbix to existing Nginx/php-fpm/mariadb and maps not saving
  • nynx64
    • Mar 2019
    Followed this tutorial to the tee besides already having nginx and php-fpm installed and running. Everything works great except when saving a map.
    The console in firefox is showing a "Error: Cannot update map. jsLoader.php:2463:13"
    Is there any additional configuration I need to do to get this running with nginx and php-fpm?
    I'm using cloudflare if that changes anything. I've also tried to save the map in IE and Chrome with the same error.
  • nynx64
    • Mar 2019
    I somehow fixed it.
    I purged all the zabbix* packages and dropped the database from mariadb. Then removed zabbix-release and then followed the same guide except I installed the 3.0 LTS version.. tested the map saving and it worked great.. so I followed the official upgrade process from 3.0 to 4.0.. started the zabbix-server service and let it upgrade the database..
    After logging into 4.0 the map saving still works.. everything else works great as well.
