Monitor service only where it is installed
  • avishni
    • Apr 2018
    hello
    is there a simple way to automatically apply templates based on service discovery ? for example if i have 10 windows servers , only 3 of them have IIS installed. how can i monitor the IIS server template only to the correct servers, and if i will install IIS on another server i would like it to be added to the iis servers that are monitored.
  • splitek
    • Dec 2018
    • 101
    Not that way. You apply teamplates to host. You need your template to discover IIS, If template discover IIS it will populate correct items/triggers/graphs. It is called LLD.
    You can search ready solution here:
