Monitoring and Triggering on Top Windows Processes consuming CPU.
  • abel5405
    • Jan 2019
    • 47
    Greetings all,
    I am very new to Zabbix and I hope I am posting in the correct forum. I have setup Zabbix to run a powershell script to collect the top processes consuming CPU and Memory and they work fine until the server is under load, then they time out. I simulate load by using (Consume.exe -cpu-time) to simulate the load. What I need is a trigger that when a process consumes 95% of CPU and/or Memory for more then say 5 minutes an alert would fire. I have scoured the forms and searched for a solution and all I have seen is that Zabbix can easily do this for a specific process, but for any process it's not so simple. Any help would be greatly appreciated. Hope this post makes sense.
    v/r
    Chris
  • ruben_1997
    • Jul 2020
    Hello abel5405!
    This seems to be very old, but I'm also looking for a way to monitor windows TOP process. Is there a way you can share your powershell script for me to try it too?
