I am looking for help,
I am wondering if there is opportunity in Zabbix to make Trigger that will close another Trigger if it's appers.
Maybe that will be easier if i will sho example.
So we got some Windows serwer on which we got zabbix agent installed.
We want to check if the
1. "Free disk space is less than 5% on volume C:" - it is high Severity
and
2. "Free disk space is less than 3% on volume C:" - it is disaster Severity
So now i want to create some trigger prototype which will close "high" 1. trigger after disaster 2. trigger appers.
This is beacue we got a lot of triggers on dashboard and I want to make it easier to read.
Thanks you in advance for your help.
and
