script for web screnarios
  • jezdimir
    • Mar 2019
    Hello guys,
    we are using zabbix for like 2 years and it is beatiful, but need your help now
    I have setupped web scenarios to test our APIs and it is working well in case to be just warn about other response than 200, it is done just by webscenarios and followed triggers on this to monitor 200. But we would like get full site header and content to the error report and now we are all lost here
    It sounds easy to just use curl, but dont know where, looking on it 2 days without success, any of you have some expierence with this kind of situation?
    tried some stuff, like make a new actions on that triggers..but it was without success,thought about made new media types, but it is little bit elephanty due it influed all disaster triggers
    any advice would be appreciated,
    thank you guys very much in advance
    Jaromir
  • brunohl
    • Mar 2019
    • 215
    What Zabbix Version are you using?
    If > 4.0
    Why don't you use HTTP Agent + Pre-proccessing?
